Did the layout for the two holes on the aft face of the F-712 and drilled these and deburred. Did the layout for the bottom holes and found that the "typical" dimensions for the three rivet holes will not have sufficient edge distance on the aft deck underneath. Removed layout marks and began again. Put the bolt holes in plans location but moved the marks for the rivets aft to provide more edge distance on aft deck.
