Clamped canopy to the frame for a final check on the cut line. Once done I removed the frame, taped the bottom of canopy for stability, and set the canopy up on some wood blocks to access the cut area all the way to the edge. Cut with Van's wheel, edge finished with multitool, and finished with 400 grit on a hand sanding block.
