Brief Description: Drill Canopy Frame for Slide Block
Clamped the canopy frame to the bench and used the slide block as the drill guide to drill the frame to #40. Had to use an angle drill to get in between the clamps. Upsized the holes for bolt and deburred all holes. Put the rollers on the frame and checked fit on the fuselage. Some bending on the frame will be required for a good fit.
