Looked at routing of brake lines from left to right seat. Decided to mount an Adel clamp on an angle bracket attached to the center support. Was able to make the bracket from a piece of the old center section cover cut off for new fuel pump mount. Bonus was I could use a section that already had a nutplate attached. Cleaned up the bracket and riveted to the center support. Installed Adel clamp and began mocking up the crossover brakelines. Finished the mockup by taping some fittings to the ends. Will take these to a local hydraulic shop and have lines with stainless steel jackets custom made.
