Stephens Web Site
Date:  3-25-2022
Number of Hours:  6.00
Manual Reference:  Section 8
Brief Description:  Rudder Cable Fairing, Install Nutplates
Ken Freeman brazed nuts on the Adel clamps to hold the rudder cables. Installed the clamps then riveted on the fairings with pulled rivets. My plan is that if I have to remove the fairings later the pulled rivets will be easiest to remove and reinstall once the tail is on.
Removed left side floors and drilled the ribs for nutplates to secure the pitot and AoA lines. Installed nutplates and ran the tubing in the wing and put the remainder in the fuselage.
Added nutplates for the removable rib section near the control sticks.
Fairing Installed
Fairing Installed
Drill for nutplates
Drill for nutplates
Pitot and AoA tubing
