I finally figured out the geometry for the fuel valve to the filter with the larger bend radius bender to get a nice smooth line that fits well. Moved on to the fuel line to run from the pump to the firewall fitting. Used another 90 degree fitting to clear the right side line. This line was pretty simple to make compared to the others. Used some thick wall plastic tubing to protect tube from vibration on floor instead of the foam block in the plans.
Washed and primed the rudder cable fairings, and the aft fuselage.
