Stephens Web Site
Date:  1-28-2022
Number of Hours:  2.25
Manual Reference:  Section 8
Brief Description:  Begin Fuel Pump Install
I bought the Airflow Performance fuel pump and filter from Van's. Installation begins with cutting and notching the F-782C center cabin cover. I cut some of the lines on the band saw and also used the dremel cutoff wheel. Finished edges with files and scotchbrite. Next was to cut a section out of the F-983C fuel valve cover. I drilled the corners and used the band saw and dremel to make the cuts, then edge finished. Removed the blue plastic and began edge finishing the F-7115A mounting plate.
Cut center cabin cover
Cut fuel valve cover
Edge finish mounting plate
