Received my Andair fuel valve and fuel pump installation kit from Van's. After going through the mounting instructions for the fuel valve I marked and drilled the center hole and enlarged it with a hole saw. Deburred and then drilled the valve to the plate. Installed nutplates on the valve and screwed it to the mounting plate. Cleco'd the valve in the cockpit for a look.
