I drilled the firewall and support angle for nutplates to secure the brake resevoir. Countersunk the rivet holes and had to order single lug nutplate for one side.
Started on the right side fuel tank vent and used the band saw to cut the end of the AN-832 union at 45 degrees and cleaned up on sander and scotchbrite wheel. Watched Karetaker video on how to bend the lines and applied his techniques. Cut end of tubing square with a tubing cutter, cleaned up the end with emory and scotchbrite, installed the nut and sleeve then flared to 37 degrees with Parker Rolo-Flair tool. I installed the AN-833 elbow in the side skin and used this to get started bending the vent. Worked the bend in several tries around the longeron and up the support before stoppping for the day.
