Drilled the elevator bellcrank for the servo pushrod per the diagram in the install kit plans. Marked the rod end bearings for half the thread length, then set up the pushrod to the 6 inch length called out in the plans. Bolted the servo to the mounting plate and assembled the servo to the bellcrank. Adjusted the bracket fore and aft to get bellcrank vertical and clamped in place.
