Brief Description: Install Rudder Cables, Start Aileron Trim
Deburred the holes for the ADAHRS bracket on the plane and the bracket. Scuffed the bracket with scotchbrite.
My fish tape wasn't long enough for the conduit that runs the entire fuselage. Used the cotton ball and vacuum trick to pull the string through. Used the tape for the string in the shorter conduit.
Received new tubing from McMaster Carr and was able to pull the rudder cables through with no problem. Ran the cable/tubing through the holes in the bulkheads then secured with snap rings cut and fit over the tubing and then snapped into the hole. Did this on both sides. Installed the Adel clamp at the aft end as shown in the plans.
Inventoried the contents of the electric aileron trim kit. Reviewed the instructions to prepare for install.
