Brief Description: Prime Flap Parts, Rivet Platenuts
Primed the flap cover and mounting parts with NAPA 7220 self etching primer.
Used the squeezer to set the rivets holding the Anti-splat cap and gusset on top of the F-705 bulkhead.
Used the squeezer to rivet the platenuts and brackets on the F-766A flap actuator channel. Cleco'd the parts in the fuselage to check fit and use the Anti-splat cross brace to make sure evrything lines up.
