Stephens Web Site
Date:  7-2-2021
Number of Hours:  3.00
Manual Reference:  Section 8
Brief Description:  Rivet Left Cover Support, Adjust Flap Block
Used the squeezer to rivet the nutplates on the left and right cover plates. Riveted on the left cover support using tank rivets as on the right side. Used the squeezer to rivet on the nutplates.
Marked the correct dimensions on the F-680 flap support and bolted it together. Cut to new dimensions on the band saw. Marked and drilled new mounting hole. Checked fit on fuselage and found it much better. Used the block as a drill guide and marked location for mounting holes. Removed block and drilled aft hole through the rib.
Left cover support riveted
Proper sized block
Proper sized block
Drill mounting hole
Drill mounting hole
