I used the squeezer to rivet the aft skin to the longeron. Double checked to be sure I didn't go too far forward where the top skin will go. Marked the "no rivet" line with tape on the clecos. Worked forward to aft and set a group of rivets between clecos on the left and right side. Switched back and forth to keep sides even. Pulled clecos and finished riveting the remaining holes.
