Brief Description: Begin Riveting F-770 Skins to Fuselage
I went around the entire fuselage and put a cleco in every other hole to prepare for riveting. Checked level right and left, fore and aft and all was good. Began riveting on the left side, forward part of the F-704 bulkhead as recommended in the plans. Used the gun and bucking bar to set the -3 rivets in the left side, then the right side of the forward F-704. Then moved to the aft section and again did the -3 rivets I could reach. Will need a partner to finish this area. Then moved to the -4 rivets in the forward flange and set those with the gun and bucking bar on the left and right sides. Finshed off by squeezing the -4 rivets in the aft side of the F-704 on the left and right.
I washed the armrest parts in Dawn dish soap and warm water and set them out to dry.
