Brief Description: Rivet Right F-704F, Prep F-757 and F-795
Used the squeezer to rivet the F-704H to the right side skin. Used the same rivets as described for left side.
Located the F-757 gussets and edge finished with files. Used dividers to swing the arc for trimming the F-757 for slider canopy per the plans. Cut the curve for the left 757 on the band saw and finished on the sander to final size. Completed edge finishing on the scotchbrite wheel. Did the same for the right 757.
Located the F-795s and edge finished with files. Did the layout for drilling the holes per the plans. Used the rivet fan to work the spacing and keep number of rivets called out in the drawing within edge distance on the long edge. Took a few tries to get everything to work out. Second one went faster.
