Made the F-796B angles from stock as per the plans. Was careful to make them left and right. Test fit with the spacers on the left side revealed the centerlines per the plans interfered with the F-902 where the spacers had to nest in the curve of the flange. Made new F-796 C and D spacers and offset the centerline to keep edge distance and make the parts all fit with the F-902. Had the same issue on the right side and so re-made those spacers as well.
Used a rivet through the stack to get a good check on fitment.
