Stephens Web Site
Date:  9-29-2020
Number of Hours:  3.00
Manual Reference:  Section 8
Brief Description:  Drill F-902, Make F-796 C and D Spacers
Marked the tabs on the F-902 top and bottom to check location of holes with edge distance on longerons. Transfer marks to outside of bottom longeron and drilled longeron hole, then match drilled F-902 tab. Did the opposite on the top longeron, drilled the F-902 tab and used that to mark and drill the longeron.
Made the F-796 C and D spacers but adjusted the length to 2 1/2 inches as opposed to 2 11/16 in the plans as suggested by Wirejock. Plan length leaves exact minimum edge distance for top hole, longer piece gives a little leeway.
Measure and mark tab
Right side drilled
Right side drilled
Spacers
Spacers
