Stephens Web Site
Date:  7-11-2018
Manual Reference:  N/A
Brief Description:  Deburr SB holes
Dis-assembled and deburred all the holes in the parts, spars, and angles. Found one hole on the right plate that was right at minimum edge distance, so decided to add another hole per the SB instructions.Scuffed the plates and angles with scotchbrite and washed the parts to prepare for priming. Also wiped down the inside of the stab.
Added hole
Added hole
Prep for primer
Prep for primer
