Brief Description: Installing the pitot sensor cable and indicators
I wasn’t sure how I was going to handle the pitot indicator lights, but after the switch plates came in, I decided and could make another label plate the same way. I made template for the lights, match drilled it to the panel and push the LED lights in from the back. This should work out fine, stay tuned. The pitot cable is also in position to be pulled through the wing. This cable is just for the indicator lights, the pitot requires 14Ga wire for power.
