Brief Description: Routing the Magnetomter and installing the map li
I ran the wire bundle for the magnetometer from the GRT 8.4 AFIS connector to the wing grommet where it will get pulled through the wing to the tip where the magnetometer is mounted. I also drilled a ½” hole in the seat support brace for the LED map light and pulled the wires up to the dimmer in the panel. This doesn’t sound like much, but I was pleased with the results given the challenges of running the wires properly, and getting everything working. The map light is great; it uses less than .04 amps and dims nicely from the panel pot.
