Brief Description: Mounting GPS Ant, ARINC, OVP & Current Limiter
I mounted the ARINC and Over Voltage Modules on the forward deck rib; I’m running out of real estate on the instrument sub-panel. Also, mounted the current limiter on the firewall and attached it to the starter relay with a piece of ½” copper bus bar. The other item finished today was running the GPS antenna wires through the eyeball fittings in the firewall, they required drilling to get them to the right size to handle the multiple wires.
