Brief Description: Move the gas line for the IO 360 M1B
This was a change that came about because the standard drawing of gas line location on the firewall is for an 0 360 with a gascolater versus the I/0 360 with a high pressure pump and filter. It would be best that this information is left off Vans standard drawing package and only put in the specific firewall forward kit for the engine you are using. This was a waste of 6 hours of time and the drawing need to be changed. It also meant wasting some material.
I followed the new drawings, added the doubler plate made out of .063 and made changes to the 3/8” fuel line to work. I also ended up using one of the thick aluminum washers I made for the original loction.
New location and mounting plate
Keep the thick aluminum washer I made for the last location
