More canopy fitting today. I needed o shorten the back to the required 1 ½” and then the bottom needed to be cut to match the top of the bottom frame square tube for bonding. I also made bushing for the rear handle so there will be no stress on the Plexi and the only holes in the entire canopy frame will be the from latch and the rear handle and they will have clearance space around them.
