Brief Description: Finishing the canopy and installing
Well the canopy is finally done except for some detail work and fixing the rear alignment block on the left side. I think it came out OK, but the design is not to my liking. I would much prefer a gull door type bonnet like those on the RV 10. This took way too much time to build and does not seal as well as the tip-up or the gull wing designs. If you think you want a sliding canopy, forget about it. It looks neat but is inferior to either of the other versions and it is sooooo much harder to build.
