Brief Description: Installing the Vetterman exhaust system
Here is a little more experience on installing the exhaust system and a few things you want to do. Use anti seize lubricant so you can remove the exhaust should that ever be required and torque the nuts on the studs to 130 inch pounds to keep them happy.
