Nothing special here just time consuming. I needed to do some repair to the paint on the panel deck from the old panel mounting. A little fill and a couple of filler rivets did the trick. I also did the scotch-brite thing on the sub-panel, radio and left panel and then Vari-primed them with a final two coats of Imron. This is done with a light dusting coat which I let dry and then a final wet coat.
