This is what I completed today on the project. The “starter on” light circuit is in and working, this is a safety feature that will always let you know if the starter is stuck on or if there is power to the engine should someone hit the prop. I also started the wiring of the pilot stick grip under the seat. There are a lot of wires so I decided to use a 25pin D type connector to get all the wires together in one place. This will allow for a grip swap if it is ever required. Last, I received the missing connectors from Whelan. They have great customer service and sent them out no charge. I installed the power supply connections and the rear wiring in the plane has been completed.
