Brief Description: Installing static and pitot lines
This is the pitot and static line installation behind the panel to the Grand Rapids AFIS and the airspeed, altimeter and VSI backup gauges. I used the push fittings and manifolds from Stein-Air, they are easy to mount with a couple of screws and the ¼” plastic tubes are easily inserted or removed as required. I like the way they work as long as they don’t leak!
Static and pitot to the altimeter and airspeed back up instrumentation
