Brief Description: Wiring the fuel pump and fuel flow sensor
This is all straight forward stuff, I drilled and mounted a grommet through the fuel pump mount and strung the wire through it to get the wire to the airplane floor. I also added a cable Ty wrap mount to the backside of the firewall to support the manifold pressure hose and keep it from vibrating around behind the panel.
