Carl Bells RV7A N947CB
Date:  11-23-2007
Number of Hours:  4.00
Manual Reference:  Laird Owens Dwgs
Brief Description:  More final fitting of the panel and brackets
Today I finished the attachment brackets for the panel including the bottom brackets that attach to the fuselage sides. After everything was clecoed in place the panel is not very strong and ridged. All that is left is the nutplates that attach the .063 aluminum insert panels and then cutting out behind them. This is going to be a pretty panel when it’s done, and hopefully very easy to work on, since each insert drops out with the instruments and EFIS attached.
With an AFS EFIS
With an AFS EFIS
Close up showing screw attachemnt
Over all snap
Over all snap
