I wasn’t happy with the standard wire Ty tabs that have double sided tape to hold them in place. After a little experimentation I settled on using Goop to hold the clips in place. It is very strong, will never separate from the airframe unless you cut between the clip and the plane and they are very strong. The downside is peeling away the doubled sided tape so you can glue them in place with Goop and waiting until the next day to finish the job. The end results are truly worth the effort, you can hang your-self on one of these tabs once the Goop has hardened they are so strong. I highly recommend the technique.
