Brief Description: Rudder pedal to firewall brake lines
I received the new brake lines from Vans today and installed them. These are the stainless steel lines that are not only more flexible but much lighter. They go from the firewall mount to the master cylinders on the rudder pedals and do not hinder the rudder pedal movement like the original heavy black hose lines did. In addition, I seal the crack around the gear legs with Pro Seal per the manual. This keeps that nasty CO2 from the exhaust pipes out of the cabin. I would guess this is a really good thing. BTW Pro Seal is still a PITA to work with, hopefully this is the end of it.
