There are plenty of articles on how to bleed brakes, so I won’t go through the process here. What I will say is that it may be necessary to pump through a lot of fluid to get all the air bubbles out and you need to start with the oil pump hose free of air. After bleeding both sides, the right side felt spongy. I pumped some more fluid through the right side and it solved the problem.
