Brief Description: Final mounting of rudder pedals and control cables
Now that the inside of “Black Bird” is painted, I started mounting parts in earnest. The rudder pedals are now in and hooked up along with all the internal brake lines. I also put in the aileron trim and will rivet the steps in place Friday.
Rudder straps in place with castel nuts and cotter pins- on for good
All the rudder pedal blocks and bolted down for good hopefully
