Today was more brake line stuff. These tubes go from the spar AN fittings to the F-6122-1 Bracket. This is how you transition from solid tubing to the flexible line on the moving pedals. These are straight forward and easy to do if you take time. I hand bend all these ¼” line, since they have to make some unique angles, which is not a problem like the 3/8” gas lines.
