Brief Description: Final Fitting of Fuselage top & wiring
I mounted a terminal block just aft of the stick for wiring the push buttons in the stick grip. This will control the elevator and aileron trim and the radio transmission button. I may also wire a flip flop for the com radio, but still need to do some research on the radio controls.
I also did all the F-774 skin drilling to the longerons, stringers and frames, I will clean up the holes and dimple next time in the hanger.
