Carl Bells RV7A N947CB
Date:  10-7-2009
Manual Reference:  None
Brief Description:  USB Cable to GRT panel for software loads
I also made a USB cable mount today for the Grand Rapid AFIS. This will let me load software updates into the systems without crawling up behind the panel to push the USB fob into the back of the display unit. It is basically just a USB extension cable mounted at the bottom on the panel for easy access. As you can see in the pictures it is a simple bracket using a platenut to attach it to the bottom edge of the panel. I also routed the cable back to the main wire run and up to the GRT Display.
Mounting plate
Mounting plate
Mounted on panel bottom edge
