Carl Bells RV7A N947CB
Date:  10-6-2009
Manual Reference:  None
Brief Description:  Coating the cowl with epoxy
Today I put the first coat of epoxy on the upper and lower cowl. I used West 105 with 205 hardener, applied with a squeegee over the entire exterior. This is the first of three coats used to fill the pin holes in the honeycomb epoxy glass cowl. I also added screw support pads on the leg fairing intersection cuffs using a mixture of milled fiber and epoxy mix. This is very strong and will allow for deep countersinking of the screws to make them flush, yet add strength to the connection.
First coat of epoxy
First coat of epoxy
Milled fiber and epoxy at screw mounts
Shown from the inside where the screws go through
