No lengthy description required here, this is a continuation of the wheel and gear fairing build. The nose gear fairing are now cut and fit in place and will now require bonding the gear cuff, filling and sanding and the platenuts. I will do this with the other gear piece once I finish the right main gear wheel and gear leg. You can see I have finished the gear leg fairing for the right side, just as I built the second one for the left side, using angle to keep it straight and after making sure it was not twisted. Early next week I will get the right fairings on an fitted and then I will start the bonding and filling process.
