Brief Description: Horizontal Injection Induction System
The induction system saga and build continues. I extended the inlet floor to extend beyond the side baffle and added a front filter bracket similar to the side ones that comes with the kit. I also bent an angle to tie the side baffle to the inlet floor. This gave the assembly the strength to use an angle for the filter hold down on the right side because there was not enough room for platenuts on the inlet floor. I will add the countersunk platenuts for holding the filter clips in place next, rivet the baffle assemblies as required and then start making the rubber baffle seals.
