Brief Description: Countersinking cowl and move heater duct
After I reinstalled the exhaust system I found the heater hose was touching the cowl. I decided to move it up which meant a longer hose and a way of keeping it in place. I used a hose clamp riveted to the heat shield to keep it in place and an Adel clamp on the motor mount. There is no other way to route the heater hose on an M1B, so it has to be the best way. I also made the pull pins for the side cowl hinges and did the counter sinking for all the flush rivets in the cowl. Once I get the Hysol epoxy I will attach the hinges to the cowl and rivet.
