Brief Description: Painting the instrument panel frame
I gave the panel frame one more sanding with 400 grit, a final coat ot primer and then two coats of DuPont Imron with hardener. When I paint Imron, I alway start with a very light coat and let it tack up. Then I hit it with one very wet coat and your done. This coat is critical and has to be done just right. Too much paint and it will run, too little and you don't get the deep glossy look.
