Brief Description: Conical Gussets for front engine baffle
Located and matched drilled #30 holes for the left and right conical gussets which server as cone shaped connector between the ramps and cylinder baffles. Deburred, then riveted. I found the best way to rivet these was in place on the aircraft using bucking bar and rivet gun.
