My RV-8 Build Log
Date: 3-2-2014
Number of Hours: 2.00
Brief Description: Ensuring Engine Bolts and Castle Nuts align
After torqueing the engine bolts, needed to ensure the bolts and castle nuts align, Given enough washers, three on each side on the top bolts, all looks good.
Order the FWF kit from Vans - this kit includes (advertised anyway) to include all needed for the FWF section of the build. Since I have an O360-A1A which I have converted to Fuel Injection using a Bendix RSA vertical draft fuel servo, I have deleted the gascolator, gascolator bracket from the FWF kit. I also deleted the alternator, since my engine has one included. I also added the Airflow Performance fuel pump since I have changed plans from carbureted engine to fuel injection.
The FWF kit should take a week, to arrive, but, the exhaust system is out of stock, and it will be a week before it ships.
A bad snow storm also hits the midwest, which delays the UPS folks even more...
Aligning Castle Nut to Bolt
Engine RIght Side
Engine Left Side
