My RV-8 Build Log
Date:  12-20-2013
Brief Description:  Engine Found !
After much researching... found an engine, an O360-A1A, at Williamson Aircraft in Orlando (Larry Williamson).
This engine is out of a Lake aircraft, is getting overhauled in January. When I receive the engine, it will be an IO360-A1A parallel valve 180 hp set up for C/S prop.
I will be ordering a new C/S prop from Vans, and will be receiving a prop governer with the engine from Air-Tec, Inc (Dick Waters).
This is a huge weight off my mind, as I have been looking for an engine for months...
Looking forward to receiving the engine, inspecting and hanging on the RV8 !
Crank and Rods, etc.
Air Intake, gaskets, etc...
Block Halves, RIng Gear, Sump
