Brief Description: Canopy Plexi Fitting and Drilling
Match Drilled - sort of - the plexi bubble to the pre-drilled #30 holes in the canopy frame using the special plexiglass drill bit to prevent cracking the bubble, clecoed as progress was made.
Re-attached the canopy skirt and clecoed, had to clean just a few holes as I went to ensure the skirt, plexi bubble and frame aligned.
