My RV-8 Build Log
Date: 4-18-2012
Number of Hours: 3.00
Brief Description: Fuel Line from Selector to Filter
After many, many attempts, finally managed to bend a fuel line that connects the fuel selector valve to the fuel filter. I used an Imperial tube bender, which is fine for simple bends of 45, 90, even 180 degrees... but if you need a compound bend, or a bend greater than 180 degrees, forget it. Had to bend and work manually, many times to get this to fit.
I think I have left enough clearance for the spar bolts. If not, it is either re-work the fuel line, or remove the line to install the main spar bolts.
looking left from the fuse center
looking rearward
looking top down
