Brief Description: Install of flap actuator motor and rod.
Installed the flap actuator motor and rod. Just a test fitting, there's quit a bit of trimming required to clear the hole the rod passes through. And.. unfortunately, there's a problem with the rear bolt alignment of the right flap block.
