Brief Description: Left Side Flap to Fuse Clearance
Based on the work performed on the right side, proceeded with fitting the flap rod and flap, testing the clearance with the fuse. Goes a bit quicker the second time. After getting the flap to retract fully, marked and trim the lower flap skin where it contacts the underside of the fuse.
I'll need to put a rivet to connect to overlapping lower flap inboard skins.
